So, after working out the issues with my lathe, I've managed to acquire a bit of 12L14, sharpen up one of the tools that came with the lathe, and cut a few chips in something that isn't PVC pipe. I think it actually went decent for someone who's never touched a machine tool before!
I do have a question, though. I was just making facing cuts at first, and as I wound the tool into the work, as I got close to the center, say 1/16" nub left, the cross slide got "tight" and didn't want to wind in as eagerly as it did when I started. I would have guessed that this is a symptom of either having the tool too high above the centerline or having the tool pointed away from the work, but I don't think that either of these is the case. I triple-checked the tool height, and it seems to be correct, and I pointed the tool toward the work by about 15 degrees, and that didn't improve the situation either.
Is there something else I should check?
Watching Quinn Dunki on YouTube, she has her tool pointed toward the work whenever she's turning or facing. Watching Adam Booth and This Old Tony, though, they don't seem to. I'm not entirely sure how I should set up my compound and tool post angles, maybe that's got something to do with it?
