- Jul 22, 2013
- 130
I wouldn't say it is perfect but it fits and will serve its purpose. I need a take up nut for the spindle on my Logan 820 to replace the collet closer nut that came with the lathe (sadly no collet closer). I need to replace it in order to get the gear cover mounted and closed.
This will be the thread Gauge to test the new nut when I make it.
Cut in aluminum 'cause I have a lot of it.
I will say that I stumbled into it more than got it right. I fully expected to trash the first couple before I got it correct. Beginner's luck. All those YouTube videos on threading I watched must have served a purpose after all.
I have found that I need to work on the dials on my Logan. Not only are they small they also are not behaving correctly. Time to take them apart and make them work better.
Sent from my Pixel 4a using Tapatalk
