- Jan 28, 2011
- 3,584
This is a build from the Project in Metal series. It will work on the 12" as well as the 10 F series.
What it does is replace the crossfeed knob with a modified version that allows a lever to move it in and out. The pin is 3/8" from the center of the shaft.
Here are the 3 parts to make it
Better shot of the mounting block
As it looks assembled
A view of the new knob. You do not need to make the headed portion as the lever will do the job now.
Here it is mounted on the apron, 2 - 1/4 X 20 cap screws hold it to the apron
