- Apr 24, 2021
- 467
Should the gibs stick out like this, also how tight should give screws be?
It’s brand new. Thank you for the response. I felt like it shouldn’t stick out and be crooked like that.If the lathe is new or has low wear, I would expect them to not sit as deep, since they are tapered gibs, as there would be less adjustment needed.
I adjust my gib depth (screw) until I have a balance between effort to move the slides and side to side play. I can eliminate all the play on my slides, but then they become very hard to move.
No, I had a hard time pulling the entire slide on one side of the gib. There are wear marks on the slide on the v ways.As long as it doesn't stick out so far that it causes an operational problem, I'd think that stickout is a good thing, gives more adjustment range as the gib wears.
When you say "crooked", is the gib bent down its length? When you pull the gib out, do you see uneven wear marks on it?
In Richard Kings class, he showed us how to straighten them.If the gib is noticeably bent, it could take a lot of scraping to get it flat; and once flat it might be too thin
