- Mar 2, 2019
- 50
Okay - so i bought one of the infamous 8x16 chinese mini-lathes from ebay after getting dicked around endlessly on alibaba. I read a lot of posts here and elsewhere about the various 'what-to-expect's from these things - only to find myself with a totally unique problem. The issue seems to be a loud squeal (electronic - NOT MECHANICAL) from what i am guessing to be the driver board (or possibly motor) but mine is much worse than other examples i have yet heard.
Here is a sample:
I wrote to the seller about this explaining how the sound gets LOUDER as the RPMs go UP (watch end of video) and if they could get me any info about the solution to this. Seller responded thusly:
i am guessing something is out of spec here - i have seen the same model lathe operating on various youtube videos WITHOUT the offending sound (sounds like an alarm of some kind like a smoke detector) - i'm pretty comfortable with electronics work (power supplies and control electronics notwithstanding) but i'm wondering if anyone might have a clue what this is ... I'm not sure about it being a 'carrier' signal due to the behaviour of the sound ... (seems different in nature to other descriptions of VFD noise) but it would be great if someone had some more insight into this. I estimate the frequency to be somewhere in the realm of 2400 hz if that rings any bells with anyone. Thanks
PS - this is my first post here and the start of an exhilarating and frightening jump into the world of 'machining' ...!
Here is a sample:
"my friend,i send the video to the factory,they said the machine works well in your video,about the voice,they said it is normal,you just use it without any worry about that,they said it is the pulse compensation,it is like a technical term,after you use several times,the voice will be decrease,so you do not worry about that "
