Looking for a bit of advice on my metal cutting options and pros and cons. Currently I have a DeWalt cold cut saw that I use for cutting large stock...sq and round tube and angle. I also have an older Craftsman 2 speed 1 1/8hp band saw that I have outfitted with a bi-metal blade to make more precise cuts with. However I have not yet converted this saw to slow the blade speed and that is my first option. I need advice on how to go about slowing down the blade speed to a reasonable amount for cutting metal. I will not be using it to cut wood. Is this a good saw to keep for this purpose or should I look for a true metal band saw. I have also been looking at the latest offering from SWAG Off Road that mates up to the latest Milwaukee portaband. Obviously much smaller, lighter, easier to store, etc. but I have no experience with it. I have a decent size shop, but most of what I do is automotive restoration and mechanical work. I do limited fabrication work, welding, structural support, roll cage....that said, when you need to cut some metal you don't want to take all day getting set up. Looking for others experiences. Thanks in advance
