- Apr 20, 2013
- 210
I have a 12" commercial craftsman and a 6" atlas 618. Tonight I got the 618 running. It is powered by a 3/4hp rockwell 3ph motor made by Baldor. Now the Dela VFD that came with my setup was a 1/2hp rated one that was rated for 3ph in. I hooked it up anyway and it runs - for about 2 minutes and then oL errors out.
So I got online and found a Hitachi WJ200 WJ200-007MF AC Drive/VFD rated to 1hp and 110V single phase in and 3ph out - sweet! Also for $20 you can add the speed/hz pot to the faceplate on the WJ200 drives so I am doing that too. So I ordered both of those.
Now my to my 12" atlas commercial lathe - it is single phase 110V. That means all my speed changes are belt changes.
I am contemplating one of two things.
1. Moving the 618's 3ph setup over to my 12" lathe and putting the 110V setup on the 618. I have not measured the spindle dia of the rockwell to see if I can change the pulleys out easy enough. BElt changes on teh 618 are easier than the cabinet on the 12". I got a countershaft so it is pretty easy.
2. Just buying a 3ph motor and second WJ200 VFD/pot setup for the 12" lathe and having both lathes be VFD variable speed equipped.
For those folks who have changed their 12" craftsman to 3ph - what motor have you installed? Is there a nice Baldor or Leeson or Marathon motor setup that fits the bill well for these lathes and their pulleys?? I am a big fan of those motors.
What do you guys use? What motor frame should i look for when sourcing a 3ph motor for the commercial craftsman bench model 12" lathe? Anyone know that off hand?
Link to the VFD:
http://www.ebay.com/itm/121046642728?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Link to Potentiometer option
http://www.ebay.com/itm/150768178103?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2649
Another nice 1hp VFD but 220V in - Teco CV-2001-H1
http://www.factorymation.com/Products/7300CV_230V/CV-2001-H1.html
Link to the VFD:
