- Dec 11, 2014
- 891
Been doing some heavy milling lately and my clutch seems to be pretty loose so as to not even power feed turning Aluminium.
I've read the Manual and tried to set it like it says, but finding a 5 lb. weight, that will fit on a rod thru the lead screw, to allow you to adjust the screws, is near impossible.
So, how do you set the clutch on the screw or what do you use to do it?
