- Feb 14, 2016
- 121
Hi everyone, it appears as though my lead screw is worn right at the spot I want to use to do a simple boring job with the auto feed. Mic'ing my lead screw on the ends (still on the threads) I get .498", but right at the spot where it "pops out" it's .491". Is that normal?
If I engage the half nut at the far right end of the bed and give a little back pressure to the carriage it powers through with no issue. But when I do the same where the worn area is, I can stop it easily and watch as the half nuts lift over the threads.
I removed the half nut and cleaned it as well as the entire lead screw.
I see lead screws on eBay but before I buy I want to be sure mine is overly worn and a non worn lead screw should fix the issue.
Thanks in advance!
Thanks in advance!
