I have tried several times to get the adapter out of my spindle to utilize what little bore I have available.
I made a fixture that was basically a puller that tried to pull a sleeve through the spindle by using a threaded cylinder inside the spindle with a boss on the other side of the MT3-2 adapter (on the chuck side) and broke the bolt trying to pull that thing through the spindle.
I've also taken a rod and tried to hammer it out (gently, but firmly) to no avail.
Someone recommended that I use heat but I'm afraid of what I might do to the Timken bearings in the headstock.
Short of pulling the spindle, what else can I do?
Thanks for any help you can offer.
KySawdust
Brad K.
KySawdust
Brad K.
