Machine:
Craftsman 12" Metal Lathe, Model 101.07403, Craftsman 1/2 HP Motor, Model 115.6962
Overview:
Just purchased lathe. I saw it work fine at purchase. Removed motor to lighten load so it could be carried downstairs. Finished building an mounting the lathe on a new bench. Tested motor on the bench. Works fine. Successfully wired in a drum reversing switch.
Issue:
When switched on the motor hums but most of the time does not start. Quickly "helping" the motor by starting to spin the pulley immediately starts the lathe up. Lathe runs fine until shut off again. Which requires the same assistance to turn.
As I said, the lathe is oiled and worked fine before removing and re-installing the motor. I am new to lathes. Need ideas as to what the issue might be. I have not comparison knowledge to know if the manual turning of the lathe pulleys and gears for this lathe is too tight or not. Any ideas where I might check for binding in the lathe headstock? I have adjusted the tension on the motor belt and that makes no difference. Motor does not spin in the belt. Rather does not spin at all without help.
Note that when I initially put the motor on last night and tested, most of the time the lathe started on its own about 80% of the time. This morning it will not start at all without "help"
Thanks!
Overview:
Issue:
Thanks!
