- May 21, 2022
- 46
I've just discovered the scarcity of SAE 20 non-detergent oil. I am looking for it in quarts/liters not in gallons/4 liter sizes. I do not want to buy a case of 12 quarts, just one, maybe 2 quarts at a time. I've tried the usual suspects with no luck.
I did a search on oil here in the forum but didn't find what I need.
1. Is SAE 20 Hydraulic oil OK to use for the spindle in a 109 lathe?
2. Which way oil should I use for the inverted bed Vees i.e. the ways?
3. Which oil should I use on the threading change gears?
4. Which oil do I use on the lead screw & compound?
My plan is to have a squirt oil can for each grade of oil. I would hope to have two, maybe 3 grades of oil to cover all the 109's needs.
Thanks!
Tony
Thanks!
Tony
