- Sep 14, 2016
- 63
I've had this lathe for a couple of years, bought it as a light duty lathe for small projects and because I was in an apartment for awhile and couldn't get my larger lathe out. So, I finally set it up found a motor to use with it, replaced the old belt with a V belt, added a switch and now while running the chuck wobbles? Measured the rotation of the chuck and its fine but the spindle appears to be bent slightly. How much of a job is it to replace the spindle?
Tim
Tim
