Hello All. I've had this for a few years but never had the time. Now I have the time and a specific need and of course there's a problem. I have a little bit of chuck wobble or vibration. I have been thinking that the spindle was bent, but I set up a dial indicator on it today and found about 0.100 play in from front to back but none vertical. I tore it all apart. It was a nightmare getting the chuck free, but it's all torn down now. I feel the issue is bearings.
Bearing are Timken
Rear (near back gear) Bearing 14125-A
Rear Race 14276-B
Front (near chuck) Bearing 16150
Front Race 16284-B
The cost of the bearings isn't so bad, but the races.... the cost of these races are nearly four times the cost of the bearings. I have found another brand (Bower) that claims to be better than timken.
Should I stay with timken and is it absolutely necessary to also replace the race?
Thank you,
John
Bearing are Timken
Rear Race 14276-B
Front Race 16284-B
Thank you,
John
