Hi -- I recently bought a Craftsman 101.21400 lathe. Even though the laead screw continues to turn, the cutting tool stops. The half-nuts and lead screw seem to be in good condition and clean. I have tried Robert D.'s advise to Alanv (Hobby Machinist 03-20-13) to adjust the lead screw by running the carriage to each end with the lead screw's mounting screws loose, closing the half-nuts on the screw, and tightening the mounting screws with no success. Robert D. also mentions a "detent spring and ball that operate on the M6-38 cam." For my detent ball to drop into my cam the half-nut lever must be at about 6 O'clock; but when the lead screw is in place this lever will only go to about 3 O'clock. Is the half-nut assembly assembled incorrectly. If not, how can I correct it? If so, any other advise to solve my problem?
Grain914
Grain914
