I was given craftsman 101 (awesome gift) but it has had some parts robbed from it that I will have to replace. I intend to restore it and use it at home. I have a question about the change gears. It came with some mounted to the lathe but no extras. If I were to make a set myself, should I use steel or aluminum? Are the gear specs listed anywhere? The person that gave me the lathe has a set that I can copy if the info isn't available.
Scott
Scott
