Setting up my first lathe and noticing the lantern tool holder needs to be angled, or rocked, nearly all the way down to reach centerline. Is this normal?
thanks for any advise.
I think a photo or two would be useful here. A slight downward angle is one thing, but really angling down at the tip is liable to give you troubles maintaining any kind of positive rake on your cutter presentation. Sounds like maybe someone switched in a larger lantern post or maybe larger tool holders?
Wrong tool holder. That looks more like a tool holder for a shaper. If you look at a copy of How To Run a Lathe by South Bend it will show the proper tool holders and good instructions. You should be able to find a copy on line.
