- Dec 24, 2011
- 6
A week ago I picked up a 101.07403 with the 36" between centers. It was in fair shape and running but really needed a good cleaning. Since I was cleaning it I decided to do a full restoration. I have it broken down into parts and I was looking at the headstock bearings. They appear to be in good shape. I pulled the spindle and removed the cones but did not remove the cups. One question is should I look to replacing the bearings anyway since I have it apart? If I do does both the cone and cup need to be replaced or can I just replace the rollers?
Also, I am looking to use electrolysis to clean some of the small parts. The big question I have is cleaning the bed? Any recommendations for cleaning that up? I was going to use brass bristle wire wheels and WD40.
As for paint I was going to primer each part once cleaned with Rustoleum automotive primer and then paint it with grey rustoleum enamel. I am a former Navy Machinist Mate so I am naturally either drawn to grey or deck red.
Thanks for any advice in advance.
Jason
Jason
