Hello all. I have an alignment question. My 12" craftsman lathe had a babbit bearing headstock, the bearings were shot so I replaced it with a timken roller unit. I have found that when turning ods I have a .002" taper consistently. The larger diameter being on the tailstock end of the work piece. I have wear on the ways but have tested at different spots with the same result.
Is it safe to assume the headstock needs to be trued? How do I test this? And can it be done?
All work was done without the tailstock.
