- May 10, 2017
- 1,199
Hello
My first lathe so everything is new to me. I picked up this lathe a few weeks ago. It appears to need spindle bushings in a bad way. I tried tightening down on the top screws but without much luck.
New bushings will be here tomorrow from Clausing, thanks Robert for pointing me there. They were about half of what Sears wanted.
So, I'm sure others here have changed these before. I'm just asking if there is anything I need to look out for? Looks pretty straightforward, remove adjusting collar and spindle gear from the end. I assume there are some set screws on the spindle pulleys and then slide the spindle out to the right. Am I headed in the right direction? Is there anything special to R&R of the bushings? Do I need to soak the new bushings in oil first before installing?
One other thing, removing the three jaw chuck. I chucked up the short end of a 1/2" Allen wrench and locked in the back gear. I gave the Allen a few sharp blows with a hammer but all I got was the back gear kept jumping out. Just hit it harder? They are RH thread ?
Forgive me for all the questions all at once.
Any and all replies, tips, pointers, or suggestions will be greatly appreciated.
TIA
Jeff
TIA
Jeff
