I worked on a piece of steel stock today and after milling off the black surface layer, I saw a crack-like line running across the surface. I needed to mill off the surface by as much as 0.2 mm before the crack disappeared. The seller of the stock told me that it was cold-rolled steel but the surface finish is kind of rough and exactly the same as hot-rolled steel stocks that I have used in the past. Is this a piece of crap ? I am not sure if I should continue to work on it.
