The engraved "protractor" scale on my Holbrook is more accurate than my eyes, although I've only checked it at a few points!
With a loupe screwed in it's within a couple of MOA when measured with a sine bar so I'm pretty confident 29.5 is +/- 0.05 degrees - if I really squint with the right glasses!
Dave H (the other one)
There is a seven step program for that, Mike...Oddly enough, I actually measured the accuracy of my cross slide index marks with a Starrett vernier protractor to see if 29.5 degrees was actually 29.5 degrees, and it is. Sooo ... I are anal, Bob!
Excellent idea, Mike!I also grind my threading tools so that the left 30 degree angle is accurate relative to the side of my threading tool so I can just slip an accurately faced cylindrical thing between the side of the tool and the face of the chuck. I do this in self defense; as I've gotten older, my vision is not as good as it used to be and I can't be all that sure I got the tip of the tool centered in the fishtail notch. You younger guys are probably okay, though.
I should have known that other machinists would be at least as anal as I am! As both you and Mike pointed out, a fixed compound setting gage for 60 degree threading is quick, easy to use, and you know where you are.Unfortunately, I happen to be somewhat anal myself. Not being satisfied with the potential inaccuracies of using the machine's protractor, I made my own gage.
