First one was to weld a new ball end on the staybilizer on the three point hitch. Next was repairing a tension pulley for the fan belt on the John Deere tractor. The bearing froze and spun on the shaft. Dealer wanted 186 dollars for a new one. With a new 15 dollar bearing from the bearing supply house it was back to the shop. Milled off the rivets holding the bearing in place and made new rivets. Tig welded up the stud that the bearing inner race ran on. The touchy part was turning the aluminum stud back down. Had to leave the tenisioner assembled and the stud was on the spring loaded side. With a few light cuts it was back to the field.
