Couple of Questions about a PM 25MV
Capt45
Newbie
Former Member
Jul 15, 2017
208
Okay; what's the best setup on a PM 25 that would benefit the newb/hobbist? I'm talking about Power Feed, DRO, ect. I'm on a budget minded constraint so bear that in mind. Need some cash left for the Tooling. Here's how I'm thinking: PM25 with DRO AND X Power feed and not a CNC situation. I've managed to sell some other stuff and have approx. $2500 to plunk down. BTW, what are the advantages of DRO without CNC?
You will not go wrong with a DRO. The power feed is also nice. If I had to choose one over the other the DRO first because you will not have to keep track of handwheel turns and a lot of operations are much easier such as finding center, bolt patterns, etc. The DRO will help a lot if you are just starting out by taking a lot of the math out of the equation, you will have enough to keep track of with out that. I think the PM25 is also a good choice.
I'm pleased after four years of usinlg my PM25 with installed DRO and home built X feed. Its done what I asked of it with no problems. I'd hate to go back to hand powered feed, although I did a couple of cuts 8" long with hand feed....
I have a PM25 with the factory 3-axis DRO. It's nice for XY but you still have to use the quill DRO for Z. I only do small stuff, so didn't get an X power feed.
OK; good responses. I'll seriously look into the DRO equipped PM25 and save a little cash and do without the Power Feed. Although, I would be interested in the "home built X feed Tom made. Got any plans, parts diagram(s) ect., Tom?
I've owned my PM-25 for just a year now and I'm very happy. I don't have a power feed and have never thought that I needed it. I have made some changes that make it more user friendly for me, though.
I added a power feed to the head, eliminating the hand crank. It's basically a windshield wiper motor powered by 12DCV.
I changed the X and Z locks to knobs that make them easier to use than the supplied ratcheting locks that seemed to catch on everything.
I changed the Y locks to a cam type system where a pull on a lever locks both simultaneously.
The quill DRO is not backlit so can be hard to read, so I removed the chip guard and used the rod for it to create an adjustable light that shines on the screen. The light is nothing more than a single diode that is powered by the same 12DCV power supply as the head motor.
I bought a piece of Plastiblocks 1" sheet and cut it to size to lock the quill for changing collets and tools. This eliminated the use of the spanner wrench, which made a world of difference.
Locktite the quill DRO screws. There are 4 of them with 2 being behind the faceplate. If they come loose, like mine did, your readings will be way off. Keep a supply of CR2032 batteries on hand for this DRO. It's easy to walk away from the machine and forget to turn off this DRO.
Nyala;
Do you have the X Y DRO with the PM 25? Pretty sure I'll find needs for that tooling.
X and Y DROs, yes, the quill DRO is all that's needed. the head moves up and down but not while machining. I used a windshield wiper motor for the Head, too, and a power seat motor for the X. both 12V.
I made a "dog clutch" from a 1/2" drive socket, to connect the motor to the X lead screw on the left. Half inch shaft coming from the motor, hex nut pinned to the lead screw. hardware to hold the two together, soft ware to adjust speed.
Nyala;
I have the 3-axis DRO that you can order with the machine. I ordered it that way after recommendations from a friend and now I wouldn't want to be without it.
I had a 3-axis DroPros on my PM25 and loved it. Using dials/counting turns is so 19th century. ;)
I used the quill dro once or twice when machining a pocket/plunge cut, but the rest of the time I moved the head and not the quill because I found it to be more accurate. The quill mechanism had too much slop in it. But this was an older PM25, not the new one. YMMV.
