- May 23, 2014
- 100
Hi,
In the past I would have picked an end mill for a particular job at random almost. Now that I'm getting more familiar with metal working I'd like to know the correct way to pick an end mill. I have the HF end mill kit. 20pc's, ten 4 flute and ten 2 flute. I'm squaring up a small aluminum block 1" x .875" x .500". What size end mill should I use? Does it make any difference? From what I've read I should use the 2 flute for soft materials but what about size? Largest possible? Smallest I can use with one pass? Smallest I can use with 2 passes? How do I decide?
Also, what about the wax on the end mill? Should it be cleaned off or just cut through it? It's not the thick wax that comes off like a sleeve. It's thinner and flakes off. I would probably use a solvent if it needs removing.
Thanks in advance. I really appreciate your help.
