Does anyone have info on these cutters? Each has 3 cutting edges on the bottom face. There’s a pilot hole thru as well as a set screw to tighten a pilot.
The boxes for the larger ones stated “Counterbore”. There are 3 sizes, ¾” diameter w/ .250” pilot hole, ½” diameter w/ .188” pilot hole and 3/8” diameter w/ .156” pilot hole.
What is installed in the pilot hole, a dowel pin, a drill bit or another endmill?
Would these be used at high or low spindle speed?
Thanks.
Thanks.
