Hey guys, I think someone cut down the 1/2" diameter steel rod that the 4 step pulley and two step larger pulley ride on. The large pulley that the motor pulley turns barely clears the cotter pin that holds in the countershaft handle rod in the armature. My question is, what grade of steel should I use if I wanted to make a longer, 1/2" pulley shaft? W1, O1, mild steel, does it matter? does it need to be hardened? Thank you! -John
