- Mar 17, 2018
- 1,400
I just got this mill handed down to me from my awesome father in law. I used it today for the first time, and I cannot believe how smooth and quiet this thing is! I'm not sure what model or generation this is either, anyone?
My main question here is this power feed that he gave me with it. He never used it. I just bench tested it and it also runs smooth and quiet, so I will begin installing it. I will need to pull out the lead screw to modify the right side to accept a 5/8 shaft. I would like to know more about it so that I can service it with the proper lubricants. This thing is really cool. It has a gearbox like an old lathe. Six gears with a high and low range, 12 speeds. It goes as fast as the Servo 150 on my FV1 and will go a bit slower and I am quite sure that it wouldn't stall going super slow, because it works with gear reduction. I was thinking of running just this on the static phase converter that he gave me. That way I could use the power feed without turning on the rotary. The tag with all of the info is completely illegible. Don't mind my bench set-up. Here are some pics!
Thanks in advance! This site is awesome!
