- Apr 12, 2013
- 562
The old steady rest that came with my lathe has concave and deeply grooved/scored tips. I figure I need to regrind them for maximum surface contact. Roller bearing tips are a far off goal...
Most of what I see in pictures of new steady rests are convex. Is that the correct profile? It seems like so long as the concave end is of a larger radius than the workpiece I would get better contact and lube action from concave grinds...???
I have a belt grinder so I can set the platen to a fairly precise 90 degrees to the belt, so grinding the tip square to the work surface is no problem. I just want to know the tip profile for best work.
