The majority of the parts I am trying to make involve making some form of a cylinder. The work typically involves a center hole, square faced ends to the hole, and turned sides parallel to the hole. One such part is a gear blank. I am having difficulty centering the hole and or holding the blank firmly to turn the gear edge if I drill the hole first. The second is a cylindrical spacer. With this part f I turn the sides, face one end, cut off the cylinder, face the second end and then try to drill the hole the hole is out of alignment.
The gears blanks are 3 to 6 inches in diameter and 1/4 inch thick. The spacers are 1 to 1 1/2 inch in diameter and about an inch long.
My lathe is a South Bend 9 in reasonable shape. It has a three jaw chuck. I am using hss cutting tooling.
My questions are: What order should this work be done? Which is machined first, the hole, facing the ends, or machining the sides?
