I am milling a case hardened (52-56 Hrc)investment cast steel part that is giving me a headache. The part has a slot down the middle that needs .004' removed from the inside of one side of the slot. I have torn up two USA made 4mm end mills (TiN) in thirty parts. Any suggestions on a better coating choice for something this hard and such a small end mill. The size of the slot necessitates the small end mill. Would a AlTiN work better?
