Converting an old bed to a bench
erikmannie
H-M Platinum Supporter
Sep 8, 2019
4,392
I am starting this thread about a third of the way through the project.
This bed is about 110 years old with .045” rusty steel tubing and presumably lead paint.
I have already almost finished the armrests. I took the baseboard (footboard) and shortened it, all with O/A brazing. I will post pictures of that after I file down the bronze.
Today I am (1) fixing dents that our landscaper made when he hit the headboard with his tractor and (2) preparing the headboard leg for welding on the mitered tubes of the armrest.
The dents are not a problem at all because I put sleeves in there anyway.
I am making two sleeves today: 1.817” diameter and 5 1/2” long.
Starting the turning. I need to take .100” off the diameter.
I prefer carbide inserts. I am at 406 RPM, power feed at .005” per revolution. This is the “medium” power feed setting on a PM-1030V.
Interesting project. Something we used while sitting in the shade visiting with another person. Keep up the good work!
Have a good day
Ray
Here is the first sleeve, the one that is intended to fix the dents. I could have made it a little larger; the effort to pound it in with a sledgehammer was about a 6 on a scale of 1 to 10. Too late now!
6118D1DF-82BB-429B-9446-B785B7490FC3.jpeg59C6DEE7-A686-4235-B786-ECA75C8D2FB3.jpegE7DD86B7-5E11-48AF-8B12-8D504768ED94.jpeg
The photos show the original white plastic feet and the new sleeve installed. I have to cut off the plastic because this bench is being powder coated. After lunch, I am going to weld sheet on there and make steel feet.
20EC7719-9BD6-4373-886C-C18AA833774A.jpeg62D9083B-E694-42F9-87E1-2A4A535D8893.jpegE786559B-ADDD-4570-9C85-D060CE5B1F88.jpeg
I used a cutoff wheel to cut crude circles out of some .120” sheet. I used a flap disk to grind down everything to bright shiny steel.
I placed the circle on top of the tubing, held down by gravity. I used an O/A 00 welding tip and gas welded on the circle. Almost no filler rod (1/16” RG45) was needed because the circles were oversized.
I used the filler rod to add material where needed.
I preliminarily shaped the feet with a flap disk. Tomorrow I will finish by hand with files and 60 and 80 grit sandpaper.
