- Feb 7, 2013
- 2,533
The older 3 phase commercial welders are ending up at scrap yards and on Craig's list and can be converted to operate on single phase.
The Miller CP-200 is one such unit that has 100 percent duty cycle and is a DC(direct current) 200 amp welder. The conversion involves
adding several capacitors and a bit of rewiring and modification along with a new single phase power cable. I presently have a CP-200
in the shop and yesterday was a day for a massive cleanup of the unit to remove as much welding blackness as possible. I went through
a roll of paper towels and a bottle of 409 and after major disassembly, cleanup and reassembly it is beginning to look fairly respectable.
I tested all six of the power diodes and reapplied thermal conductivity goo under the diodes on reassembly. The fan was the biggest nightmare
as it took me an hour to remove it and another hour to clean all the black off the blades. I ended up using laundry soap and a Scotch Brite pad
to get down to the aluminum. On the web are step by step conversion instructions. The power control dial assembly was completely
stuck so obviously this machine has been sitting in some unused corner for a long time. With some cleaning and a bit of oil, the control dial
works nicely and in good shape. The infinitely adjustable power control is a great feature. I expect I will have to add some wheels to the unit
and paint the cabinet Miller blue as it is looking a bit shop worn after 50 years of hard use. One of the side panel covers is missing so that
will be another project after it is up and running.
My camera quit so I was not able to take any photos but I did extract a photo off the web so you can see what a CP-200
machine looks like.
DC welding will be a new experience to me so looking forward to a bit of learning curve with something new to me. These old units are
more dependable than the new light weight IGBT welders and still have their place in the shop as being very dependable. I don't know if anyone else
has any interest in saving old 3 phase welders from doom but certainly worth doing in my opinion. I will make another post as to how
the project turned out for anyone interested in this sort of activity.
machine looks like.
