- Oct 17, 2018
- 966
CHANGE GEARS
I have converted my 101.07403 from a change gear lathe to one with a QCGB. I know I need to keep certain gears (I was told in another thread, but I can't remember right now what they were) for making metric threads, but what other gears should I keep? I think I saw a Tubalcain video where he kept a gear set that reduced the feeds by half. I think as long as it's a set that has a 1:2 ratio and doesn't interfere with the other gears, then it will work. For example a 16/32 of a 12/24.
NAMEPLATE
Should I change the name plate on the back? The lathe is a 12x18, so it's not really an "official" 101.27430 (12x24) or 101.27440 (12x36).
DONOR LATHE
The donor lathe is all fixed up and ready to sell. It's a 101.27440, but without the change gear box, it's really a 101.07403. Should I leave the original tag on this one, or switch them/get a new one?
I'm leaning toward just leaving everything the way it was originally, but I thought I would ask and see if it mattered or was important.
NAMEPLATE
DONOR LATHE
