- Apr 29, 2019
- 2,250
My mill currently has an old Sieki 2 axis DRO. The florescent display is showing signs of old age. I am trying to figure out if there is a way to use the already installed scales and add a scale to the knee for Z and then add a scale to the rotary table and have it all interface with the Touch DRO? I am not sure how to determine what type scales are on the mill now and if they would be compatible. It is the mounting of the scales that is the part I look the least forward to.
I would also like to add a Touch DRO to the lathe, I would assume that I could use the same tablet for both machines? Possible to have them both on at the same time and just switch screens back and forth for the one I am using at the moment?
I do a bit of playing around with electronics, but if it requires ANY software or firmware, it is above my pay grade.
I started a new thread so as not to hijack the one that @Schtimpy had started on just his rotary table as that is just part of what I am doing. But I will be watching that thread for info on the rotary part.
