Contouring Shapes In Lathe (and Mill)
randyc
Feb 5, 2015
662
This is a duplicate post - a response to another thread but I thought it might be of interest to the folks that read this particular forum often.
I occasionally use carbide router bits as form tools. There are many, many shapes to choose from and they are cheap compared to the time expended to grind a form tool from a 1/2 inch HSS, as an example (if time is of importance).
Easy enough to make a temporary holder for router tools that works in a 4-way or a QC tool holder. As with any form tool, the lathe should be run very slowly using lots of cutting oil. In the mill, the opposite applies - run the tool at a fairly high RPM (but with very slow feed) occasionally brushing a little oil on the cutter.
Router cutter in a vertical mill to produce a special contour - high RPM, slow feed is required.
PS: The steel workpiece shown in the first couple of photos is a back gear lever handle . It can be seen (way back to the rear of the left end of the headstock) in this photo of a 1944 Sheldon EXL-56B.
I knew they could be used on metal but I never realized how versatile they could be. Thank you for posting! Maybe even make this a sticky?
Sadly though you can't get any back rake without messing up the form..
  • Like
Reactions: Rob
Hope its all right to chime in.
Using a rounding over bit to profile a stack of aluminum sheets.
Greg
Thanks for the contribution, Greg, that's a very good idea !
this is a great idea !
i have been using router bits in my woodworking routers and shaper for over 40 years and have just recently got into machining.
now the possibilities are endless.
Dan
Thats an interesting way to use an router bit !!! I would have never thought about that.
I have had this thought almost every time I walk by the router bits. I see that many of them are made from carbide or HSS. Now I will definitely have to get some. Particularly interested in the corner rounding bits. Thanks for the write up and pics.
I've been using the curve on a roman ogee bit to round the ends of small brass screws.
Works excellently.
I cant wait to try it on some aluminium plate edges.
