I ran mine through the block wall outside. It froze up once last winter. Probably because we had a few days of North wind and was especially cold. Easily thawed out with a electric heater. I have both the air dryer and compressor drain going thru the wall outside. Only because the air blasts gets annoying.I have my drain hose going into a bucket, just to save a possible mess. A lot of folks run their line outside through the wall. I worry about freezing myself. I have mine plugged directly into a wall socket. Mine is a Rapid Air, but there are several on Amazon also.
I doubt Rapid Air makes them, they are probably the off the shelf Chinese products, maybe the higher end specs.I have my drain hose going into a bucket, just to save a possible mess. A lot of folks run their line outside through the wall. I worry about freezing myself. I have mine plugged directly into a wall socket. Mine is a Rapid Air, but there are several on Amazon also.
only problem with that is controlling the water. I get a lot of water. I built a muzzle so it disperses the water in a jar. Rather than having a high stream that blows all over the place. I wish I was smart enough to have thought about it before I re-did my sump area. I have a lexan cover glued down with silicone, I could have drilled a hole and put the muzzle under it.We use a similar drain valve on the compressors at work. Whole different environment, but we've got them dumping six seconds at 20 and 40 minute intervals. But at home.... You're probably better off as you are, cycling it with the motor. If (if.....) you're interested in running the drain outdoors, and you're worried about freezing, (ours don't freeze, ever), after the valve, First, put the discharge into a quarter inch poly tube (air brake tube on Amazon), you'll get very good velocity, and still a good volume. Second, make sure there's "some" slope in the tubing from the freeze point, which will be probably somewhere in the wall to a few inches inside, so water can't pool. Third, during the warm (humid) months, pay attention to see that ALL the water drains, and there's one and a half or two seconds of "dry" air to blow the tube out after it discharges the water. That's your insurance policy, The warm air caries WAY more water than the dry air that you have at freezing temperatures or below, so even if you find a sudden higher than normal use in the winter time, you won't build up enough condensation to exceed the drain time and loose the "blowout" at the end.
I'm in a pickle at home. When I gave up on small compressors and finally got a commercial one (well, box store commercial one), I put a tether valve on the bottom. I've got the cable set up so I can just kind of push it with my foot to drain the tank. It works well enough that I can't bring myself to upgrade..... Automatic is still better though.
