- Jun 24, 2024
- 44
My 7 x 14 lathe is a pain to turn the compound rest handle.
I have seen several ways to help.
Drill attachments in the form of forks and "T" handles are good.
But my lathe only has one extension on the crank.
After thinking about this for a time I got to thinking....
How many of the small grinders I have trashed for failed switches and worn gears, maybe 4 or 5.
Well, it came to mind about where I put those old screw in handles.
I found one and examined it.
Hollow inside and 1/4" screw.
I took it to the band saw and cut it down to a useable length.
Put it in the lathe and turned the flange down.
I then notched it to fit the cross bar on the handle.
With a little tinkering I soon had a useable crank adapter for the battery drill that was plastic and would no score the cross-slide handle.
Try it, you will like it.
