do you know what size and type of collets you are going to be using?
there are a few choices for example,
5C- very common , you'll need a collet for every size of work you'll be turning. you will need an adapter and hollow drawbar for your spindle , a Collet Chuck, or a Collet Closer arrangement.
ER series(16,20,32,40), ER's are becoming more common.
they consist of a specially designed holder that goes into the spindle of the lathe that is retained by a solid drawbar . One adapter is capable of holding the range of ER series collets in that series,
(IE -a ER16 collet is not interchangeable with a ER32 collet and vice versa)
ER's are nice but there is a notable shortcoming, you can't pass long pieces through a ER collet.
you are limited by the holder's depth clearance, whereas 5C's can usually pass fairly large stock directly through the collet for faster production
