Hi guys,
I'm hoping for some advice.
I bought a lever operated collet closer off of eBay a week or so back. It's beginning to look like much less of a bargain!
The main bearing had seized and while I freed it up it was rough as and had a lot of play. I decided to do a complete strip down to fix the problem along with remedy any other issues whilst I was at it.
Anyway, the main body of the part seems quite worn. I guess the best way to determine if it's too worn would be to try it out but as it's in pieces and I'm at a stage where I'm questioning whether it's worth the effort I thought I'd ask for some input.
You can see some grooves worn by the locking dogs. What are peoples thoughts on this? Still usable or would I be better off making / sourcing a new one? I guess if this has worn significantly then chances are the dogs are worn also.
It was advertised as in good working order but I guess at this stage it's a bit late to go back to the seller now as I've had to machine the bearing retaining nut off the other end.
Thanks,
Sam
Thanks,
Sam
