Collet chuck holder for a lathe: what to choose and how to install?
Hello all,
I want to buy a collet chuck set and a collet chuck holder for a mini lathe I have.
I have started machining just 2 month ago and I have never seen a collet chuck mounted on a lathe, so I have doubts on what should I buy and how can the different choices be installed on the lathe.
I was looking for 2 types of holders, My lathe has a MT3 head stock :
Is that rear part that treads on the MT3 shank mandatory or can I use the collet holder just fitted in the lathe without it and the centrifugal force will hold the holder in place??
Will this work well and allow me to produce more concentric and accurate pieces or solution 2 is far better?
2. Collet holder plate
Will this fit directly or I will need any kind of plate adapter?
Will this work better that solution 1?
I more inclined to buy the solution 1 because the holder is included in some sets at a better price.
Thank in advance for your help.
Best regards
Vasco
Hello all,
- Collet chuck with a MT3 shank
- About collet quality, what should I be aware off? Cast or aluminium? I dont want to buy bad chinese quality but I would like to spend as little as possible.
Best regards
Vasco
