Collet Chuck for PM1030-V lathe
Red96
H-M Supporter - Gold Member
Apr 24, 2022
182
Hello all,
Thought I'd share how I adapted a PM Tru-Set ER40 collet chuck with D1-4 mount to fit a PM1022 or 1030-V spindle. The PM D1-4 collet chuck doesn't fit the 1022 or 1030 lathes out of the box, but adapting it is pretty straight forward.
The chuck is two pieces bolted together using the common (for 4-6" chucks) 3 hole on a 4.250" bolt circle arrangement. Back half is the mount plate with a protruding hub, front half is the collet holder with a recess for the hub on the mount plate - this hub is what the trust bolts push against to adjust runout. Back has a centering taper (approx 2.5" at widest) on the backing plate meant for the D1-4 spindle.
I bought a couple extra spindle mount plates from PM with the Lathe, anticipating to use one for a collet chuck project. Those also have holes at the 3-on-4.25"-circle. They have a centering hub that is roughly 3.75" in Dia.
So, all the needs to be done is to separate the chuck and bore the tapered hole square. I just chucked it in a 4-jaw and dialed it in using an indicator running on the mounting taper. Figured that would be concentric to the collet holder. Ended up with a 2.500" centering shoulder.
Then mounted the spare 1022/1030 mount, and turned the shoulder down to 2.498", for a nice snug fit to the collet chuck mount plate. ( It's cast iron, so...)
3 M8x25 bolts will be needed. Take .040" off the bolt faces for clearance, and bolted it all together. Was able to dial the chuck to less than a tenth, with indicator riding on the collet taper, so I'm happy. Should provide good utility, didn't cost much, easy to make, and there were few options available for the 1022/1030, so I have no complaints.
Pm sent me the plate for the 4 jaw chuck and that has 4 mounting holes so I didn't use the collet chuck mount plate I just needed to drill and tap the 3 mounting holes and I was done. First test run had it out 4 teens and I was more than happy with that.
Thanks for posting this I will get a lot of use out of this..
