Most of the steel that I work with is cold rolled steel or 1018. The reason for that is the supplier I buy from is in the Philadelphis Pa area, is within driving distance and is cheap.
I have used 12L14 and have found it to be better to work with and usually yields a better finish than 1018. It also seems to knurl better than 1018.
I originally tried to knurl 1018 with the knurler that came with my QCTP and always with poor results. Somewhere along the line I get the idea of making my own knurling tool. Only this time I thought of trying a scissor type and purchased a pair of knurling wheels (Medium & course) at $10.00 a pair. I made one tool using the $10.00 wheels both medium and coarse and I get what resembles a decent knurl the first 2 or 3 uses. I made a second tool tighting up on some of the tolerances which didn't seem to be any different.
I have noticed wear on the wheels in fact the screws that they ride on are scored. Either these wheels are to soft or i am applying too much pressure or doing something wrong? Is 1018 noted for this problem or am I missing something?
In a previous post one of our members mentioned the possibilty of buying a better set of wheels,that is my next move. In the mean time I would appreciate any comments or suggestions
Thank You.
John Romano
Thank You.
John Romano
