I finally got my US machine VT mill wired up and running(I use that term loosely…) now my issue is the belt which drives the gearbox for the head is missing the belt…I threaded a piece of paper into the spindle and around the other pulley on the gearbox as well as measured the width of the groove in said pulley on the gearbox and came up with a 3/8x17” belt being needed…then I measured 10 teeth on that pulley and got 57mm which you divide by 10 to get 5.7mm it’s at this point that I am lost…I am certain that it’s a imperial belt being that the mill was made somewhere around or before WWII…can anybody help a feller out with this? I found this belt on zoro which you gotta buy 5 of them but I got no issue with having extras but if I’m understanding correctly the t85 means 85 teeth total? See I’m all kinda confuzzled now…
