- Aug 22, 2012
- 4,273
An absolutely urgent job that had to be done no matter what.
The grid that the cup sits on when making a coffee was chrome plated plastic. Considering the cost of Jura coffee machines ****** me off some what.
After 4 years of approximately 6 coffees per day that poncy plastic cover disintegrated and a new one from the maker was priced at $45 which I didnt feel like forking out for.
No worries, we all make stuff in a hurry for that really urgent job. and believe me this was very urgent as I cant function without that breakfast extra strong coffee.
I had a small bit of polished stainless sheet that would work so I made a paper template to check out the folds and cuts, transferred that to the sheet, cut it out and folded it up using angle iron sections cut to the inside lengths.
I drilled the holes at 4mm dia then drilled a 6mm dimple in a chunk of wood, using a M6 acorn nut screwed onto a bolt as a punch I dimpled all the holes.
Removed all sharp edges and the plastic protective coating and voila, my cut now can sit safely and be filled with rich fresh invigorating coffee.
