- Nov 16, 2020
- 15
I've got an early Dunlap 109.0702 that someone had bought back gears for an home made a change lever. it may work ok once sorted out.
My issue is the spindle is bent slightly.
I'm considering making a 5/8 spindle and boring the headstock to accept Larger Bushings.
Main reason for this is the 1/2 hollow shaft needs replacing, and someone has put on a larger heavier chuck.
Any thoughts?
Any thoughts?
