CO632 lathe - how to remove saddle?
AlfromNH
H-M Supporter - Gold Member
Nov 1, 2022
140
I have this new to me lathe which seems to be in nice shape but pretty grungy. I’d like to remove the saddle and can see that the 5 screws on the top plate separate it from the apron. If I do that, the apron will only be supported by the feed screw and lead rod. Is that the proper disassembly process?
What is the make and model number?
Do you have an exploded view of the machine?
That's where I like to start.
Daryl
MN
You probably will have to remove your carriage lock, the two hold downs on the underside of the rear way, and if there is a gib for the long travel, that will have to go too. Support the apron with wood blocks and lift off the saddle.
Thanks guys. The lathe is a Yangzhou brand, but my understanding is it was sold under many different brands including Grizzly and Jet. I have a few manuals with exploded parts diagrams but it wasn't clear how to remove the saddle and leave the apron in place. Thanks @pontiac428 I'll support the apron with wood blocks when I remove the saddle.
I got the saddle off, as well as the apron. This isn’t a restoration, simply a much needed cleanup, possibly its first in nearly 30 years. Here’s a couple before and after pics. A very satisfying experience, now reassembly begins…
