- Dec 27, 2018
- 3
I am working on a project at home, and the only tools I have at my disposal are a drill press and a hack saw. My objective is to drill two co-axial holes in aluminum scrap to adapt a 1/4" shaft to a 2mm shaft. The issue I am having is that my holes are misaligned by a degree or two, which is enough to cause the rest of my system to seize up.
Here's my procedure:
1) Cut a ~15mm section of 1/2" aluminum rod stock with a hack saw (apologies for mixing units)
2) Clamp the stock into my drill press. Adjust it so that it's close to vertical with a square. This isn't super critical for me, as long as the holes are properly co-axial
3) Adjust the drill press table so that I can drill my 5/64" hole all the way through, and step up to 1/4" half way through. This way I won't have to adjust the table between presses
4) Start a hole for the 5/64" bit so it doesn't wander around too much. Here's what I've tried
a) Center punch
b) Starting a 1/8" hole
c) Starting a 1/4" hole, a bit deeper
d) Make sure that the 5/64" bit is as far up in the chuck as possible.
5) Slowly drill the 5/64" all the way through, adding a little bit of tap magic lubricant
6) Switch the bit, and step my way up to 1/4", drilling only half way into the stock
My drill bits are cobalt HSS jobbers.
The final result always has a degree to a few in axial misalignment.
My guesses:
1) The 5/64" bit is bending and wandering off axis as I drill.
2) The bit changes are introducing an axial offset. It's a relatively cheap drill press. Perhaps the chuck doesn't have good tolerances.
3) The hacksaw surface of the aluminum is relatively planar, but is not square, which definitely doesn't help the drill bit stay on track
Suggestions or advice would be appreciated. Thanks!
a) Center punch
My guesses:
