- Oct 16, 2019
- 6,873
I've wanted a small CNC plasma cutter for a while. I can't afford the space to have a permanent table so I scoured the web looking for ideas.
Biggest criteria is size; it had to be small enough to fit on my 2x3 welding table or be portable enough to store out of the way.
Discovered Dacs Garage and his design.
Watched all the videos several times and decided to spend $10 for the plans which include .dxf file so the pieces can be waterjet cut if so desired.
The electronics are an Arduino Duo controller running GRBL and Universal G-Code Sender.
I run a Macbook so no Mach 3 or 4 as they require a PC. I may do that in the future but I need to get my feet wet first.
I bought an import Sungoldpower 60A blowback start plasma cutter to go with it.
Portable CNC Plasma Cutter
dacsgarage.com
Non Touch Pilot Arc Plasma Cutter 60A
Sungoldpower Non Touch Pilot Arc Plasma Cutter 60A Hightlight: ★ Non-touch Pilot Arc: it efficiently cuts though rough, painted, and rusty surfaces and produces minimal slag;the technology allows you to cut without touching the tip to the metal. It provides a better cutting quality and longer...
sungoldpower.com
