I’m finally getting around to starting up my G0704 CNC Conversion and after reading blogs, forum posts and watching a ton of YouTube videos, I’m still thoroughly confused about the details of wiring things up. So I have a few questions I’m hoping someone here can address
1. My Z axis motor (Nema 34 906 oz) is Bi-polar and needs to be wired accordingly to get all 906 oz of holding torque. However it seems you can wire that in series or parallel. What is the preferred method? Advantages, disadvantages?
2. The Bi-polar wiring of that same motor means 8 wires. I’ve seen people simply combine wires at the motor and run them to 4 conductor shielded cabling to go to the controller. Is this correct? Is there any advantage or reason to run 8 individual wires to the controller?
3. I realize that the motor wires and the limit/home switches should be wired with shielded cables. It seems to me that any other wire (possibly adding spindle control later) that runs from the mill to the controller should also be shielded. Do any other wires need to be shielded? Like the wires that run from the breakout board to the stepper drivers? Or is that unnecessary?
4. I’d like to buy the shielded wire type that has the drain wire. If I’m wiring these motor cables into xlr (aviation style) plugs, where do I attach the drain wire? Do I simply run it to the metal body of the plug, to one of the motor wires, or to its own terminal (which would require a 5 conductor plug instead of 4.
5. I know I need to use 18 AWG wire for my z axis stepper, and 22 AWG should work for my x,y steppers. I gather that 22 AWG should work for the remainder of the connections between breakout board, controller, limit switches. Will 22 AWG be sufficient for the connections from the power supply too, or does that need to step up to 18 AWG as well?
6. Should I need to install fuses anywhere in this system? I feel like I’ve seen some people setups incorporate this but I’m not sure if it’s necessary or how to go about it.
